- 4 Feb 2011
Gigabyte Release AORUS MO34WQC and MO34WQC2 34” Ultrawide Monitors with QD-OLED Panels - TFTCentral
Share this contentGigabyte have now launched the product pages for two new 34” QD-OLED monitors in their popular AORUS gaming line-up. The two screens have very similar specs and features,....[click link for more]
tftcentral.co.uk
MO34WQC2 Gaming Monitor
- Panel Size (diagonal)
34" OLED - Display Viewing Area (HxV)
800.06 x 337.06 mm - Panel Backlight/ Type
OLED - Display Surface(non-glare/ glare)
Anti-Reflection - Color Saturation
99% DCI-P3 - True Resolution
3440 x 1440 (WQHD) - Pixel Pitch
0.2315(H) x 0.2315(V) mm - Brightness
250 cd/m² (Typ, SDR APL 100%); 1000 cd/m² (Typ, HDR APL 3%) - Contrast Ratio
1.5M:1 - Viewing Angle
178°(H)/178°(V) - Display Colors
10bit (1.07B) - Response Time
0.03ms GTG - Refresh Rate
240Hz - HDR
VESA DisplayHDR True Black 400 - VESA Certified ClearMR
ClearMR 13000 - Flicker-free
Yes - Connectivity
2 x HDMI 2.1
1 x Displayport 1.4
1 x USB Type-C (Alternate Mode; Upstream port; Power Delivery up to 18W)
2 x USB 3.2 Downstream ports
1 x USB 3.2 Upstream port
1 x Earphone Jack
1 x Microphone Jack - Earphone Jack
Yes - Speaker
3W x 2 - Unique Features
Tactical Switch
OSD Sidekick *
Black Equalizer 2.0
Dashboard
Crosshair
Timer
Counter
Eagle Eye
PiP/PbP
Auto-Update
KVM
6 axis Color Control
Apply Picture Mode
HDMI-CEC - Power Type
Power Board Build-in - Power Consumption
48W ** - Power Saving Mode
<0.5W - Power Off Mode
<0.3W - Voltage
AC 100-240V ~ 50/60Hz - Tilt(angle)
-5°~+20° - Swivel(angle)
±30° - Height Adjustment (mm)
130 mm - VESA Wall Mounting(mm)
100*100 mm - Kensington lock
Yes - Phys. Dimension with Stand(WxHxD)
811.7 x 595.3 x 244.3 mm - Phys. Dimension w/o stand (WxHxD)
811.7 x 361.2 x 105.8 mm - Box Dimension (WxHxD)
990*527*238 mm - Net Weight with stand (Esti.)
9.86 kg - Net Weight without stand (Esti.)
6.68 kg - Gross Weight (Esti.)
12.5 kg - Accessories
Power cable/HDMI 2.1 cable/DP cable/USB cable/QSG/Warranty card - Note
*To enable OSD Sidekick (integrated in GCC), it requires connection between PC and monitor with HDMI/DP cable.
**The test condition follows CEC standards.
