Gigabyte RTX 2070 fan rattle
15 Jun 2020
i've had this graphics card for almost 2 months and it started with a slight rattle which i was fine with at first but its gotten progressively worse and i'm not sure what to do, there is nothing obstructing the fans which i can see.
RMA time.
Oh thank you, how would I go about arranging that? :)
Contact whoever you bought it from, tell them it's faulty and that you want it repaired/replaced and they'll issue you an RMA number.
Depending upon who it is, they'll either email you a pre-paid label or you'll have to return it at your expense.
You might be able to claim the money back, but you'll have to read the terms regarding that.
Thanks so much :)
