I have a gigabyte UD5 and a raid 5 array with 4 1TB Samsung drives (HD103UJ)'s
Setup with 300gb raid 0 and the rest raid 5.
When in windows I can browse the internet for a bit and then the machine locks up. The only way to resolve this is by a reset. Then when it boots back up it needs to rebuild the array. 48hours later the array rebuilds and I can go about my business for 5 -30 mins then it locks up again, need to restart and the raid rebuilds itself again. This only happens on the raid 5. The computer never locks up or needs restarting when rebuilding. Does struggle if i do stuff on it ie unrar files etc. so its best left alone. Well its spent the best part of a week and a half rebuilding and crashing so I m getting a little miffed. The south bridge is roasting on the mobo, should it be too hot to touch on these boards? Is it being overworked or is the mobo faulty? Has made a slight high pitch noise but I solved that by turning of one of the power saving features in the bios. So any ideas guys?
Its not the same hard drive that fails either? Going to run some hd tests but i think the drives are fine plus will prob take me yonks to test them.
Cheers
Cheers
