Gigabyte Z97 AIO pump, which header?
1 May 2013
M28
pump will be using 3 pin connector.
Could connect straight to a 12v but would mean running full pelt all the time.
I know from my current board Giga is not the best for fan speed control.
Attach it to the CPU fan header.
Cheers, any idea what would be the best BIOS option for that header from these ? :
Normal - Allows the fan to run at different speeds according to the CPU temperature. You can adjust the fan speed with SIV based on your system requirements.
Manual - 0.75 PWM value /oC -> 2.50 PWM value /oC
Full Speed - full speed :D
Full speed for the pump and usually many AIO coolers the fans plug into the pump and it (via software) controls the fans.
