I'm pretty sure the power supply has had it, I've had these speakers about 10 years. I need a replacement 27V 1.7A power supply.
On the marketplace I can see a seller advertising one specifically for the Gigaworks T20 which I'm certain uses the same power supply. But the seller lists it as:
"Output: DC 27V - 2A; // Safely compatible for 2.0A,1.75A,1.5A,1.0A,0.75A,0.5A as amperage isn't forced."
So it does 1.75A not the 1.7A that I know this speaker uses. Do you think this will be a problem? I've tried to ask the seller but they don't reply.
