Okie, Ive been packed up and arrived at uni now for 2 and a bit weeks...
Ive been suviving on very rubbish pc speakers (you know those next to free ones that get very crackly and tinny all the time...)
The only reason I have to stick out these was because i couldn't bring my 5.1 surround system with me - Its attached to my old room's walls - and slightly overkill for my small uni room....
Sooo... As I now have my loans etc... and possibly some spare cash....
I could do with something that'll sound very good on a budget.
I have digital optical and phono connectors from my X-Mystique Gold 7.1 card. I could just use the bog standard front speaker output (which i rather wouldn't).
Over to OcUK. Can you spec me a system that would possibly use digital input, and will put out some good overall sound. - Thinking no more than 100w/channel, or possibly dammned good 60/80w? Sticking with Stereo.
If I've been vague, ask away for any more info.
Ohh the budget.. as I do have something set up at home, and I'm a student... can possibly stretch to £200? maybe a little more depending if it'll make a big difference for a little more.
Thanks!
Alex
Thanks!
Alex
