- 8 Sep 2003
- Outside
After deciding that I didn't want a quartz splashback behind the hob as it would look a bit odd snaking up the wall, I've gone for standard 100mm upstands all round. I have an angled cooker hood so it's left about 400mmx900mm clearance between the upstand and the hood.
I'm planning to fill this gap with either a clear or colour matched (to the wall) glass splashback for a semi-invisible fit.
Does anyone have any recommendations for suppliers (self-fit) and whether acrylic or glass is the way to go?
Ta
Ta
