- 27 Mar 2013
I plugged them begone I started audessy, it still set them to largePlugging port alters response probably set speakers to small 80hz
They are 3050is, but matte. Gloss white seems like a very rare finish, only available on expensive speakers. I think the setting to small is to stop there bring too much bass, and the fact that the sub will do a better job. Also I'm not sure if the manual crossovers only work on small.Looking nice mate. I was looking at those, are they the older 3050 in gloss, not the 3050i?
I got some kef q550 in white. Really REALLY wanted that piano white gloss finish on the kef r500, but the amp to run them properly would have cost an extra £1000 or so. I looked into painting them but piano white is a hell of a lot of work.
No idea who said they wouldn't touch the speakers with wrap... They're easy to wrap as others have said. I'm considering trying it with much more weirdly shaped kefs soon, will post here if I remember.
I really don't get the HiFi world with setting speakers to small... All it does it stops your fronts from producing bass and sends it all to the sub.
Not sure about you but I love the bass my kefs produce (although there's not a lot). Still sounds perfectly balanced (if not more) than even a "accurate" Bowers & wilkins sub when both are on. Each to their own I guess. It's supposed to put less strain on amp, but Meh. Why bother buying floorstanders if you're just gonna use them as tweeters/high mids?
