Is that £500 (£499.99) just for the case?!
Nice one Ian, case looks awesome. Had the D600 and that was a joy to work with, now is there one without your logo saving £200?????![]()
I remember a 14 year old me trying to get a chieftec dragon full tower back (all time classic) home from work, some 16Kg of case plus the packaging
£200 extra for al logo is so over the top or has the case been changed from the bog stanard case what the extra cost for ?
It's closer to the D666 in size but it's even larger, the exterior panels are redesigned, roof rad mounts redesigned, it has much more watercooling capacity and it has a dedicated dual pump mount.£200 extra for al logo is so over the top or has the case been changed from the bog stanard case what the extra cost for ?
Amazing, love it. So much radiator capacity in that beast. Who needs caselabs when you can get this now![]()
I have the Lian Li PC-05SX and PC-07S which have the same finish I expect. Usually not that easy to scratch but when I did I used Birchwood Casey Aluminium which did a great job of blending the scratches.
^^^ This is ofcourse personal taste and I like Caselabs. I still offer a Supernova in Caselabs for those who ask. Its not a problem for me to build in that Case.
But for this spec of case if you did use Caselabs it would be a couple of hundred pounds at least more maybe even three hundred. You have Import Duty to pay on importing the Caselabs and also payment for each Radiator mounting bracket and flex bay as well as ofcourse the case its self.
Ian, get OcUK to check then, because PC cases should not have any import duty, it should be at a zero rate.
