God damn Ipod Nano
13 Jan 2004
South East
Well, i just bought an iPod Nano, so far i absolutely love it.
But, on the back of it, when i was unpacking it, there was a clear sticker with loads of foreign writing on it. So i peeled it off, only to find it left a patch of gooey sticky stuff behind, which i now can't get off. I can't believe it, I bet the sticker says "Do not peel this off".
Anyway, If i use some acetone or similar liquid with a cotton bud, firstly will that be safe, and is it likely to help me get this **** off?
Thanks in advance
nah the sticker says something about listening for long periods of time may damage your ears, at least thats what i think the french bit says dunno bout german im guessing its on same lines :p
im sure it wont damage it try google tho
Thanks in advance
mines the same lmao...
get your finger and rub it really hard til it kinda burns and it should come away
Acetone melts plastic, use IPA (NOT IPA beer, but clear alcohol), dampen a cloth with it and just rub the stickyness off. 10 seconds. Sorted.
K.
K.
hmm, dunno what IPA is, but i wont try the acetone then, although its not really plastic on the back.
Glad its not justme that had the problem, you would have thought they would just not put the sticker there, or put it on the bit with the headphones in
Isopropyl alcohol.
Chemists should sell it in small quantities, it's a very handy cleaning product to have kicking around, but don't drink it!
K.
NICE ONE! This method worked a treat :) thanks
Feek said:
Isopropyl alcohol.
K.
yeah i got some of that too for when im switching CPU's. But its all sorted now, thanks to the trusty hard finger rub method :)
oh so it actually worked well it did for me!! thought you might have been taking the mick but thats all i did i just rubbed it until it burned my finger and it all peeled away.
ScarySquirrel said:
no no no, it really worked, only took like 10 seconds, sounds really simple but i honestly didn't think of doing that.
So the thanks is a genuine one :D
glad to hear it. shame it burns your finger like but nvm! lol
