Going for Gold!
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Arriving in a few weeks are the new HX+ Gold Series of PSU from Corsair. These boast an amazing 7 year warranty.
Corsair Professional Series HX+ 650W '80+ Gold' Modular Power Supply (CP-9020030-UK) @ £99.98 inc VAT
The Corsair HX 80PLUS® Gold certified modular power supplies offer quiet performance, with a fanless mode at low power loads, and the flexibility of using only the cables needed for a clean system build with optimal airflow. Industrial-grade specs like a 50C power rating and upgraded internal components like high quality 105C capacitors back up legendary HX series quality, and provide you with peace of mind for a full 7 year warranty.
- Fanless operation at low power loads
- Low profile, black modular cables
- Continuous power output at 50C
- 80 PLUSR Gold Certified efficiency
- Multiple GPU ready
- Industrial grade components, like 105C high quality capacitors
- 7-Year Warranty
Only £99.98 inc VAT.
ORDER NOW
Corsair Professional Series HX+ 750W '80+ Gold' Modular Power Supply (CP-9020031-UK) @ £119.99 inc VAT
- 7-Year Warranty
Only £119.99 inc VAT.
ORDER NOW
Corsair Professional Series HX+ 850W '80+ Gold' Modular Power Supply (CP-9020032-UK) @ £139.99 inc VAT
- 7-Year Warranty
Only £139.99 inc VAT.
ORDER NOW
Corsair Professional Series HX+ 1050W '80+ Gold' Modular Power Supply (CP-9020033-UK) @ £169.99 inc VAT
- 7-Year Warranty
Only £169.99 inc VAT.
ORDER NOW
How do these compare to the AX series? looking to buying a new PSU amongst other bits this weekend, should I hold out given the £15 price difference on the 650W models?
Power supply is the heart of any good PC. The last thing you'd want is for your PC to have a heart attack during a good gaming session, so it's worth a few extra quid to buy quality :)
ThundyCat happened, I merely suggested that his home page on his PC was of something you wouldn't want your kids to see, so he changed my name as revenge.
Why do you need a modular 24pin and 4+4 pin cable?
YOU MUST USE THESE FOR ANY DESKTOP PC TO WORK!
Exactly...
If they said not modular because you can't braid those cables, then maybe. Even then not many are bothered to and just buy the extender.
Also a modular 24 pin cable is much larger and harder to route.
Just get the AX if you want full modular.
From a purely aesthetics point of view, it does include the 24 pin and MB connector, but also has 2x6pin cable built into it making it semi modular. The cables going from the PSU are from the TX range and the far better quality modular cables included in the bag are from the AX range. The PCI e cable has a different coloured connector to the one going from the PSU. Picky I know, but will sway me to get the 650/750 AX
