Mine has a power mode which will make it redline before changing, and also you can turn the overdrive off which will give engine braking. Its a lot better around town with it off, as like you say it gives engine braking, only downside is you only get 3 gears with it off.
I dont think I'd like an autobox where I'd have to choose how it behaves like that
I fail to see why gearboxes need so many settings, what's wrong with a clever one that works out whether you are going around town or not...
Yeah one that links to the sat-nav and detects road patterns - If it sees a long angular road starting with A or B and has numbers in, hold on to the gears as long as possible![]()
[TW]Fox;16456955 said:lol rypt, always thinks he knows best![]()
Give me one good reason why what I say is not possible?
Handbrake on else you'll be blinding the poor sod behind you![]()
I dont think I'd like an autobox where I'd have to choose how it behaves like that. Mine will redline (well, comes to about 50rpm of it!) before changing up if you put your foot down - it also seems to change quicker the harder you're pushing on. Drive it gently and it's changing up at much lower revs and does it much slower/smoother. I think it adapts to how you drive over a period - after a hoon, it feels "funny" around town for a few minutes
I've had 2 days experience, how much more do I need to know I prefer changing gears.
Automatic cars just don't feel right, just generally an unsatisfying drive as it's so boring, at least when you're changing gears there is something to do with the left side of your body.
Volvo 850 estate, automatic.
It crept forward if the handbrake was on in drive.
Even when you put your foot down it would take a good 2-3 seconds to drop a gear and the acceleration was painful, so slow.
Manuals are superior, you can have fun in them, on the motorway pop it into 6th and chill out and clutch control is just majorly useful when trying to squeeze into a tight parking space.
[TW]Fox...it's all about the irony.
[TW]Fox;16458301 said:Because it will never be able to predict with 100% certainty the desired driving style.
