Going from Nvidia to AMD
Caporegime
24 Oct 2012
Yer nan's knickers
Hello!
I received my R9 290 today to replace my GTX 770. I've installed the card and it seems to be working fine. All I did software wise was uninstall EVGA Precision X, install Catalyst and update.
One thing I noticed is that when I tried AMD's own autodetect tool, it said that it was unable to detect my OS or GPU.
Has anyone else had this? Seems a bit odd that AMD software can't detect AMD hardware.
It's nothing major, the card's working fine, just thought I'd ask.
Cheers!
As long as you can see a boost in performance, then I wouldn't be concerned. I only use programs like driver sweeper / cleaner, and so on, when I have to. All you should need to do in almost all situations is to :
Uninstall old driver - power down machine - remove older video card & install new card - boot up machine - install most recent driver and away you go.
