Explicit said:Akasa Amber or Vantec Stealth because OcUK don't have Panaflos, otherwise I would have said Panaflo.
get yourself a couple of those and you will be ready to make your very own black hole, light cant even escape the force of those deltasTaKeN said:Delta's.![]()
CS||nuTs said:Need some new 120mm fans what should i get? CPU cooler is a XP120.
CS||nuTs said:I,ll be the flash bugger in the S-Type![]()
TaKeN said:I thought more CFM was better than more pressure ?
Can anyone tell me if im correct or not![]()
erm.. maybe noise as most people are going for quite systems and just dont like deltasNeon said:I had 3 deltas in my case 120mm on an xp-120?
whats the problem?
bbreezeuk said:erm.. maybe noise as most people are going for quite systems and just dont like deltas
