Going to buy the Lian-Li PC-7+
29 Nov 2006
And the side window too.
This is the pic that has made me want this case now :)
Are the blue led's for the power and the front fan standard or is this a mod?
That's a mod, standard one's are green for power and orange for HDD. Will be modding mine, probably to blue and white, in the near future I think, as long as I can find some LED's that aren't stupidly bright as most seem to be.
it depends sometimes it's blue led sometimes it's black, you would probably want to replave them anyway for some really nice silent fans
p4radox said:
I think that's with the Lian Li PC-007
Yup thats all stock on the PC007.
The PC7+II comes with standard LED's and a non LED fan.
Depends which version you get, but it is oh so easy to mod your case and it can be done for under £5. :)
I have the case, and I love it, you're making a great choice there!
However, my dad, God bless him, got me the V1000 Plus case from Lian Li for my birthday yesterday, now i'm just waiting for it :)
Anyone fancy me old case?? :p
I used the PC7+ as my first case for my first build and it's probably the best choice I made.
As i've posted in the other PC7+ thread, mine has arrived today as well. Not opened it up yet, but will do soon. Can post pics if needs be, but they'll not be brilliant quality as they'll be taken by the camera on my phone.
Ok some pics, as i said they are through my phone and the light wasn't brilliant, so they're not great. If they're too big, let me know and i can resize them. Anyway the case is very nice, packaged well. It does have 2x120mm fans (as you can see) and the build and finish on it are quality, a nice clean look about it. Loving it already and can't wait to build my new system in it.
Yep someone has changed the leds to blue ones and i think it looks miles better. Its really easy to do on that case as they're just 5mm leds clipped into a plastic holder on the case front. Its just a case of unclipping the led, desoldering, re soldering, reclipping into case, easy.
Here ive found a thread where i did the exact same thing.
http://forums.overclockers.co.uk/showthread.php?t=17528468
