hi,
going to install it on a blank partition i've created using PM8, on the same disk as my winxp install.
i've not formatted the partition to any format (NTFS etc), will the partioning be done when when i run the install from dvd ?
i have tried searching for the info, closest i came to the answer is when someone has actually pre created the partitions b4 install.
thx for u;'re time.
thx for u;'re time.
