Going watercooled need help
16 Nov 2011
Hello fellow clockers, so after purchasing my new Coolermaster storm stryker case in gloss white and being happy yet still sad (wanting to upgrade pc more) i received a bonus from work £1100. using this money i want to go with a liquid cooled system. To start with i have an intel i5 2500k processor with a LGA - 1155 cpu socket and a MSi Z68A-GD65 motherboard, 750watt overclockers cpu- 16gb corsair vengence RAM. now i have done a bit of shopping via overclockers and i have come up with this kit so far, i am wondering will i need to buy anything extra for this or should i swap certain bits for others. also will all this fit in my case (full tower lots of room to improvise.) i have also added a picture of inside the case at the minute incase anybody is wondering (just thrown it together quickly excuse the very bad! wiring.)
and here is the components i have found to buy so far.
change from 360 hfx to 240hfx
http://www.overclockers.co.uk/showproduct.php?prodid=WC-001-OP
http://www.overclockers.co.uk/showproduct.php?prodid=WC-172-EK&groupid=962&catid=1532&subcat=
http://www.overclockers.co.uk/showproduct.php?prodid=MO-027-AS x 3
http://www.overclockers.co.uk/showproduct.php?prodid=BB-006-LP
http://www.overclockers.co.uk/showproduct.php?prodid=WC-132-EK
reason for the new monitors is i want 3 the same that i can run off the gtx680
so that's all please help guys will be ordering tonight if i get some helpful responses, many thanks. ~callum~
