Good atx psu with 80 or 92mm fan?
22 Dec 2008
England
I like the straight-through airflow design, but the market is moving away from me. Today I use a 860W PC P&C which has been superb, but it's approaching it's 7th birthday and has had a hard life.
Is there a credible replacement? Dropping to 600W would be fine. I'd like to avoid the noise profile of server grade kit.
Swapping to a 120mm fan is possible, but forces unwelcome compromises elsewhere. Thanks
Man of Honour
12 Jul 2005
Aberlour, NE Scotland
Just about all manufacturers have ditched that approach now and psu's are more commonly fitted in the base of a case these days so that they draw air if from under the case. Most have a 120mm, 135mm or even a 140mm fan. At a guess I would say it is because it directly cools all of the components equally whereas a straight through design causes hotspots due to other components disrupting the airflow.
