Good Case For AIO?
25 Apr 2016
I currently have a Fractal Torrent which is a nice case. I have a Thermalright Phantom Spirit 120 which is a great cooler but I am now doing a lot of flip fluid baking in Blender and the processor (i7-13700K) is starting to thermal throttle.
So apparently the Fractal Torrent isn't great for AIO's? Apparently. The AIO I am getting is a Deepcool Mystique 360.
There are so many cases around does anyone have any recommendations as to what would be a good case to use with the AIO to get most benefit.
Thanks
why is Fractal Torrent not good for AIO?
It can fit a 360 in the front (or bottom, but thats not ideal for AIO to have pump at the top of the loop) after 180mm fans are removed
Since rear mesh is the only direction air can escape, positive pressure setup with intake front and bottom should create a nice flow.
Second assembly example here
I thought the same thing but have read so many reviews where the AIO is producing higher temps than the air cooler for some reason.
That review seems to show the thermals with the air cooler rather than the AIO(unless I have missed it)
Yea, TPU reviews reward cases with good airflow, this has a whole torrent.
But there is nothing inherently unsuitable for AIO about it. More so if you add a 140 rear exhaust
But then again, the air cooler you have should already be good enough, especially in this case. Here it almost matches a 360 aio https://www.tomshardware.com/reviews/thermalright-phantom-spirit-120-review/2
Did you try refreshing thermal paste or reseat? Maybe one of those custom intel frames for better pressure?
Yeah done the whole 9 yards. Tried MX-5, 6 and Thermal Grizzly. I have the Thermalright frame. Just can't get temps down. Don't get me wrong I am knocking on the door of 97 degrees so its still within spec for the chip but I can see its thermal throttling in HWInfo so there is room for improvement.
The CPU is limited to Intel spec so 253W. I am wondering whether its a bit too much for the air cooler.
That graph shows the max wattage it could cool was 234W so as I am over that I am guessing its just getting a bit swamped.
Think what I will do is try the AIO and a 130mm exhaust and if there is a problem will look at a new case though can't really see why there would be an issue.
Problem with reading too many reviews, ends up messing with your head.
it is a hot CPU and you are pushing it hard.
I would say there are not many cases with better airflow than torrent and not many cooling solutions better than yours.
Maaybe some other cooler would make better contact due to different base convexity? but no way to predict
Try undervolt?
I am looking at a Deepcool Mystique 360 to replace the air cooler
Edit to above, meant 140mm exhaust
Oh should have said why I was asking about the case. I have only just got it so still in the return period :) So its no big deal if I had to change it
