- 12 Sep 2005
- Norwich, England
hi, whats a nice easy, good, £30ish, easy to fit cpu cooler for the q6600, which will be on the abit ip35 pro. cheers
hank
hank
Don't stick the backplate on with its supplied sticker use masking tape to secure it in place then put the heatsink on.Do it with the board on a flat soft surface makes it easy.
I use a thermalright ultra 120 extreme with 2 sharkoon silent eagles fitted.
Chip is a warm B3 overclocked to 3ghz. It sits at 40c idle and rises to nearly 70c under 100% TAT load.
Watercooling next i feel!
gt
ok thanks, im split between the tuniq tower and the Thermalright Ultra-120 Extreme now.
