Good cooling case <£50
27 Mar 2004
Manchester
As title really.
I've just bought a OCZ ModXStream Pro 600w PSU and want advice on a case that will suit it. I'm slightly worried that the PSU only has one fan.
Would I be better with a case with a bottom mounted PSU or not? Would a case with a bottom mounted PSU and a side fan might be ideal??
It needs to be minimalist and under £50. Ideally i'd like to try something rather than an Antec 300.
Cheers.
as you said something other than an antec300, I'll avoid recomending that one :D
well you have 2 choices, a) within your budget a coolermaster elite b) slightly over your budget a coolermaster cm690 dominator (much better, imo Id stretch the extra fiver)
or for £48 delivered a Coolermaster 590, can't tell u the site though, but just think northern company (hope thats not against rules too :D).
I have the antec 300 atm, and just waiting on a few water bits, before i swap over to the cm590, but from looking at it, seems a lot better then then antec 300.
he get's free delivery, i think spend that bit extra for the 690 as it can have more fans, got more space and better cable management.
bifday2k your sig is too big please read the FAQ.
Yeh i guess, i went for the 590 as its easier for water cooling, especially with the drive bays easily being able to handle a 360 rad.
But i would have to agree for air cooling, and cable management the 690 beats the 590.
My apologies about the sig, just copy and pasted from another forum, thanks for letting me know it was to big..
I meant to add that an external 3.5 inch Drive would be preferable.
Does the CM690 have one or not? I know the Antec 300 doesn't.
You cant go wrong with either the antec 300 or cm690.
Have recently built systems using both cases, and imo,the extra for the 690 is worth it.
If you need a spare 5.25 to 3.5 bay, in black, let me know and i can post you one FOC, if you get the 300. Got a couple spare.
You offered me one in another thread as well. :)
Thanks again but i'm leaning so something with a bit more space inside. Is the CM690 a bit roomier inside?
what about the CM scout case or is that too much for you?
No, i'm willing to pay a bit more especially if the case comes with most of the usable fans included. I wouldn't want to buy a case for £70 and only get one fan included.
I see the Scout has 3 of 4 usable fans included. How many fans does the CM690 come with?
I must admit I do like the Scout. I did want a minimalist lookind case but at least it's not as 'flashy' as the HAF922. The Scout has a bit more character than the CM690 and I would prefer red fans rather than blue.
Cheers for that. I'll look into it.
