good gaming build? Thoughts and help please
25 Aug 2013
I am making a computer for gaming and video recording/editing, this is what I have so far, can anyone say if it is good/bad, and any parts i should change. Also i am not too sure about the graphic...i was planning to get AMD due to BF4, what would be the best £200ish card?
Also how do i know if the motherboard works with everything including the case, and is a full case required? Budget £800ish
Aerocool Mechatron Gaming Case
Gigabyte AMD Radeon HD 7870 Graphics Card
Corsair CMZ8GX3M2A1600​C9 Vengeance 8GB
Intel Core i7 4770K Quad Core Retail CPU
Western Digital Green - 2TB Desktop SATA Hard Drive
Samsung 840 Series 120GB 2.5 inch SATA Solid State Drive
Corsair CW-9060007-WW Hydro Series H60 High Performance 120mm Rad All-In-One Liquid CPU Cooler
Corsair CX750 Builder Series CX 750W ATX/EPS 80 PLUS Bronze PSU
Gigabyte Z87X-D3H Motherboard
IIRC there was a bad batch of them with poorly mounted heatsinks/too much TIM. I could be remembering that incorrectly though.
Regardless of what you go for £200 should get you a 7950 of some description, which is generally a better card than even the 7870LE (which I own).
i will defiantly note that down...thanks :)
i do not even know what xfire is/does so thats not my intention really
Xfire is multi AMD GPU's so two 7950's in one machine..
If that £800 is to include your spec and a Gpu, then you will be struggling. You would be looking closer to a £1000.
Is it your intention to go xfire in the future?
I think you're right £1K seems about right:
YOUR BASKET
1 x Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor - Retail £275.99
1 x MSI HD 7950 Twin Frozr III Boost Edition 3072MB GDDR5 PCI-Express Graphics Card **NEW REVISION** with FREE GAMES £189.95
1 x Gigabyte Z87-HD3 Intel Z87 (Socket 1150) DDR3 ATX Motherboard £99.95
1 x Samsung 120GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE120BW) £86.99
1 x Corsair Hydro H80i High Performance Liquid CPU Cooler £78.95
1 x Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST2000DM001) HDD £68.99
1 x Patriot Viper "Black Mamba" Generation 3 8GB (2x4GB) DDR3 PC3-17000C11 2133MHz Dual CHannel Kit (PV38G213C1K) £65.99
1 x BitFenix Shinobi USB3.0 Gaming Windowed Case - Black £59.99
1 x Akasa Venom 550w Modular '80 Plus' Power Supply £53.99
Total : £1,007.71 (includes shipping : £22.45).
do you think i really need the water cooling thing? or would the air fans be enough?
Stock cooler?
I think you'd need an aftermarket cool atleast.
The only reason i dropped the H80 in is i saw a H60 in your orignal spec..
Otherwise a cooler like this would suffice:
YOUR BASKET
1 x Silverstone Argon SST-AR01 CPU Cooler - 120mm £28.99
Total : £34.97 (includes shipping : £4.98).
I'd say go for air cooling to save a lot of money... Unless you're looking at seriously overclocking the cpu
You can get serious overclocks on air coolers.
What you should have said is:
"Go for a sub £30 cooler unless you're looking at seriously overclocking the cpu"
