- 20 Sep 2006
- Southampton, England
double post
squiffy said:Zero case air movement would concern me using that shroud.
squiffy said:Zero case air movement would concern me using that shroud. I have a similar setup, large HP passive, case exhaust at 7v. So it's extracting air from the case including heat from the videocard, rather than forcing air through the CPU.
Btw, what system is this for? we are all assuming its an INTEL Core2 Duo? (LGA 775).vipergrm said:I am looking to purchase a good CPU fan that is extremely quiet. I am currently using an Arctic Freezer, which is just a little noisy as it whirls at 2,500 RPM![]()
Big.Wayne said:Btw, what system is this for? we are all assuming its an INTEL Core2 Duo? (LGA 775).
If its AMD I got a feeling the Thermalright heatsinks will be facing upwards, not ideal for either but an extra bad move if u get the HR-01 series?
DFI maybe, ASUS and others nope.WJA96 said:Nope. They fire east/west just like the Core2Duo systems.
Big.Wayne said:DFI maybe, ASUS and others nope.
