good spec, low fps
6 Jan 2017
Bought a new mobo and CPU A couple weeks back and since have been having issues with fps across all games, CSGO runs at 90-150fps for a while until CPU warms up then a 5-10 second stuttering with 20-30 fps occurs, WoW running between 20-40 fps in heavy environments overall in minimal settings.
Current hardware:
https://gyazo.com/bb0b7594349041458bef7816d3d40dad
https://gyazo.com/acf595980a623e0236dd141fc5e6ad4f
powered by a Corsair CX600M
Upgrades have been an AMD FX8350 with a a rock 990 extreme3 motherboard
other indications something inst right is that my CPU seems to be working harder and the fans are louder... here are some other readings...
Open hardware monitor:
https://gyazo.com/5c4cb103651efdd8cf2a02e7c3484b92
AMD overdrive:
https://gyazo.com/366f5bd8c42a7e27efd0682be9ffca79
If there is any more info anybody needs to help me sort this I will be happy to send it over as
any help, information or advice is appreciated
Thanks, James
cpu could be throttling, make sure heatsink is making direct contact with the cpu.
thanks for the help :) I have checked the heat sink and thermal paste, the thermal paste seemed a little low so I applied a little more and same problem occurs
I'm thinking this could possibly be an issue with the ram not being quick enough for the cpu or possibly the heatsink or gpu, maybe it could be a hardware issue since the new mobo and cpu was such a big upgrade from the previous but I have no solid evidence of it and don't want to go spending if its something that can be tweeked to get it working stable
