Good Wireless range booster
8 Jun 2006
Hertfordshire
Guys
I tried a Belkin range booster but I couldn't get it to auto attached the the Netgear router via the wireless?
Main router in the office downstairs and I want to boost the signal to an office upstairs?
Anyone got any recomendations?
Personaly I've never had much luck with wireless repeaters, Id look at buying a N standard router or consider running a cable
i bought a 1w wifi amp and it boosts the signal on my ps3 from 15 to 95%
1 Watt? Unless your PS3 is on the 10th floor of a towerblock and the router is below, it's complete overkill. You could achieve the same results by getting a set of directional antennas instead without adding more noise to the 2.4ghz band.
Oh, and 1W is 10x the legal limit here in the UK.
Where did you buy from out of interest?
