Google Page Speed - LCP issue: longer than 4s (mobile)
30 Nov 2011
Hi all,
I have a wordpress site that is about 1 year old now.
I just noticed in Google search console I have the error LCP issue: longer than 4s (mobile).
It is coming back with a LCP of 4.4seconds.
I don't have any web development experience. I built the site with Wordpress and the help of Youtube.
All the suggestions I see I have no idea on what they do or mean haha.
I did try some random plugins that "minify" the javascript/css but I don't think it made a difference so I got rid of them.
Any thoughts? Should I be concerned?
I am running Ezoic ads on the site, pretty sure that is probably causing the vast majority of the slow down.
Thanks,
Sean
Have a check on gtmetrix and google page speed to see whats slowing you down. An optimisation plugin and caching should help a lot with wordpress.
It may be worth looking into AMP for mobile speed too.
Do you have any suggestions for the best plugin? I think I did have one before but got rid of it as I think my hosting has its only. one.com is the host.
I have seen AMP but need to do some more research, I thought I read it blocks ads?
Cheers,
Sean
I have just added an AMP plugin and W3 Total Cache. Did not seem to do anything, I ticked the minify and cache on. Made little to no difference.
It now reports minify.js as being part of the problem in the google speed test.
EDIT-
AMP is being reported as working now I cleared the cache. I shall retest
I was going to pay someone on fiver or something but I'm not sure they would do anything different to what I have already done.
I'm not too sure on the best as i haven't tested them all but i am getting good results using autopitmise. If you're not already using an image optimization tool that can make quite an impact too, im using shortpixel because they had a good app sumo deal :P.
I'm not too sure on the best as i haven't tested them all but i am getting good results using autopitmise. If you're not already using an image optimization tool that can make quite an impact too, im using shortpixel because they had a good app sumo deal :p.
Already have short pixel. I even export from photoshop with high compression first. Images are few and far between and well compressed.
I installed W3 Total Cache as that is listed as being compatible with Ezoic. I have reached out to Ezoic as they apparently have a AMP conversion app. Hopefully that helps.
Pretty sure it is the ads/ezoic that is causing all the problems to be honest. The rest of the site is pretty basic and 99% text/basic theme.
Page speed insights is a bit miss-leading really. It'll tell you defer loading important javascript like jQuery, and even Google's own analytics and ads code causing problems with it.
Largest Contentful Paint (LCP) measures the time it takes for the largest above the fold content element to load. Items that appear only when a user taps the screen or scrolls down don't affect LCP.
This could mean you either have a banner or something like Slider revolution or an image that's to large loading when you open your site.
Hard to tell unless you show us what it is and I can work it out.
