Permabanned
- 22 Aug 2004
Oh I was hoping you popped in as I saw your pics after you cut a lot of water
Wow, really drinking a lot of water is the way to cut water weight? I really thought that would be the opposite
Someone said lowering protein would help massively, as well as said above, lowering carbs. Dont really want to cut my protein shakes but will if I need too
Lowering protein wont do much. What you need to do is convince the body that iit doesn't need to retain water. The best way to do that is to stay hydrated and the two best ways to do that are to increase water intake and lower salt.
As mentioned cutting carbs will help reduce the bloated look and cutting sugar has the same effect as cutting salt. If your retaining water however and its not because of any 'substances' then you should analyze your diet, its not normal to retain water weight. Oh and dont fall into the misconception that cutting water will massivley impact your physique, cutting fat does that, cutting water helps uncover definition and expose muscle.
