That can't be right? Wholemeal bread? Can of Tuna? That alone is about 450cals, banana 120ish, shake 120ish with water iirc.1x protein shake
1x tuna sandwich + 4 boiled + greens
1x banana
50g pro / 20g fat / 404 kc
Can I have is circa 200cals+ (sunflower oil). A 'proper wholemeal bread slice' is approx 100 cals each.A can of tuna with two slides of whomemeal bread is not near 450kcal
7.00pm
1x Chicken slice breast 25 3.4 120
1x Pasta 11.4 72.6 1.4
1x Water
1x Salad
1x Homemade Yogurt
38.4p 72.6c 4.8f 120kc
Cheers, that is interesting.good questions barf0r :]
simplist answer is calories. to get bigger you eat more than you need, to get smaller you eat less, to stay the same you eat as much as you use.
you can use the same routine as the OP, just when you near your target you level off your kcals.
to answer your 2nd question: read my other answer but also add to it: don't stop progressing your weights, your body will get used to it so you will need to keep raising the bar to stay at your target :]
