Hi guys,
Got a 750gb in a new build that I wanted to partition, post-windows 7 installation, I thought GParted / Partition Magic would be the easiest option as I've used them both in the past but upon booting into each program I get the same error prompt (something about gpt iirc) that gives me a yes/no options pane. The drive is then determined to be 'unallocated'.
The drive was formatted during the os install to ntfs and once I've restarted, boots back into windows fine? Any ideas
