GPT Protective Partition not readable help!
17 Jul 2008
I have a windows 8 pc that will not boot
I took the HDD out to read in another pc
the other PC sees the drive but no partitions
disk manager shows "GPT Protective Partition" with no options to do anything (they are all greyed out)... a mac just says the disk is unreadable
any tricks to sort this?
Both 64bit 8.1 both uefi,
Hmmm the other PC probably used different SATA cable plugged in HDD so that is why it showed GPT Protective Partition. You must use exactly same cable that plugged in HDD in first PC then it will remove GPT Protective Partition and you will able to access GPT Partition.
