- 17 Apr 2011
- In front of my monitor
Hi all,
Long story short. Ive managed to knock off two tiny surface mounted (which I presume are) resistors. You know the ones, about the size of full stop lol.
No other damage has been caused and the board is not physically damaged. The tracks are fine and the pads to which these resistors were mounted look fine. Card has not been turned on since the damage, so presuming I can get replacements soldered on by somewhere it should be good to go.
Card is a gtx580 which may (most likely) have been reduced to a paperweight by my stupidity
So is it possible? Does anyone know where I can get this done?
.So is it possible? Does anyone know where I can get this done?
