I was bored at the weekend and noticed the GPU client didn't have an icon, which made my Quick Launch Bar look untidy!
So, boredom being the mother of invention, I created an icon. I bet it'll be better than Stanford's effort!
So, first of all you will need the icon file.
http://www.twobeds.com/upload/userfiles/BillytheImpaler/GPUClient4.ico
Once you have the file, stick it in your GPU Client's program folder.
Now, you can't add the icon to the [email protected] directly... instead make a shortcut and place it wherever it is going to live [Quick Launch in my case]. Right-click the shortcut and click Properties, under the Shortcut tab you should see a button that says Change Icon...
Click it
Click browse, find where you deposited the file and click OK. Then click OK again. Then OK again...
Tada! You have a nice shiny icon courtesy of SiriusB. Since the icon file is living in the GPU client folder you should be able to move the shortcut anywhere you like and it wont lose the new icon.
Heres a screenshot of it in action... woo desktop pr0n.
SiriusB
Click it
SiriusB
