GPU for £50
9 Sep 2012
What is the best second hand graphic card i can buy for £50?
My friend is selling his Gigabyte GTX 650 Ti 2GB OC for £50.
Can i get better than this?
Thanks.
The 7950 was about as powerful as a 670.
So to compare 650Ti - 660 - 660Ti - 670. So yeah, much faster. At 1080p it would be like twice the performance.
Yes a huge difference. Which processor and PSU are you using at the moment?
Fifa will work fine with the 650TI but for 1080P Witcher it will struggle a little, not too much though.
I have a 7950 crossfire setup and in single card mode it's fast enough for most games, even Witcher 3 if you turn hairworks off. You should be able to get a 7950 for around £70 used for a non-reference card so well worth it over a 650ti.
is 580 better then a 650?
o_O
Essentially the first number is the generation and the second is a model so *50 is the lowest end card of that generation and *80 is the highest. a *50 from the next generation tends to be around a *60 from the previous generation so a 650ti is roughly equivalent to a 560.
