- 19 Oct 2002
- Torbay, Devon, UK
Ok
I have purchased 2 HIS 7950s (Boost Versions).
I have done a fresh install of Win 8 so I know its not nvidia driver related.
These cards have duel bios. I flash the flashable bios as in http://forums.overclockers.co.uk/sho...php?t=18539905.
Both card would not run on that bios in xfire. Stock bios that worked. So I started to test each card. Both failled in the top slot in each bios position. Both worked in the middle slot, again both Bios Positions.
So I thought it was the top slot that had failled.
So I removed all AMD stuff, in driver fusion to clean the drivers out.
I plugged my GTX 670 back in sorted the drivers and it ran 2 runs of Heaven.
So Im confused, it cant be the board as it runs my GTX 670. It cant be the 7950s as they both run Heaven in the middle slot.
So any advice. I have a few days to return the 7950s to OcUK under DSR.
My Board is Gigabyte Z77X-UP5 TH. http://forums.overclockers.co.uk/sho...php?t=18433746
PSU 750 OCZ (ran GTX 670s in SLI).
RAM is Sammy green passed memtest fine.
Im lost what to do.
Im lost what to do.
