gpu help
17 Feb 2011
hi everyone i do not no a lot about gpus so i am wandering how you tell when looking to by a gpu how Meany pcie express power conecters a card requires to power it and i now some do not need any see below
so my question is when shopping how do i tell how many pci express connections my psu would need to have to power a card
http://www.overclockers.co.uk/showproduct.php?prodid=GX-102-MS
http://www.overclockers.co.uk/showproduct.php?prodid=GX-251-AS&groupid=701&catid=56&subcat=1752
thanks in advance
read the description on the web page would help you in the first instance. If it doesn't state any requirements then it does not need them. :p
5450 = none
6970 = " 1x 8pin and 1x 6pin PCI-E power connectors required (Power Adapters included in box for older PSU's)"
