Can someone answer to my q. is it possible for rtx 3080 to move from upper slot 4.0 x16 to a bottom slot without to insert it so just to screw it to the case ,and just use a riser gen 4.0 and connect it to a upper pcie slot with riser cable,so basicly i want my gpu to be at a bottom of the case (lian li pc011d) and still using it/and be connected to a upper slot?
gpu rtx 3080 gigabyte gaming oc
case lian li pc011d
www.phanteks.com/Riser-Cables-4.html
case lian li pc011d
