GPU not being detected by mobo
11 May 2013
Hi I recently built my own computer but my GPU is not being detected. When I go into the motherboard settings it says the PCI-E slot is empty. It was working fine before but after I installed the drivers from the AMD website there is no display.
My GPU:
http://www.overclockers.co.uk/showproduct.php?prodid=GX-303-SP&groupid=701&catid=56&subcat=938
My Mobo:
http://www.overclockers.co.uk/showproduct.php?prodid=MB-235-MS&groupid=701&catid=5&subcat=2574
Thank you :)
EDIT: After some googling people are telling others to disable their onboard graphics, however I am reluctant to do this because if I do and my GPU doesn't work I'll have no display, right?
I do remember putting the GPU in the 2nd PCI-E slot and it did work for a bit, but now it has the same problem.
If you do disable the on-board GPU and the PCI-E card still fails to work you should be able to recover the MB settings by using the reset button below the top two usb ports.
Best to familiarise yourself with the reset process before making any major changes as some MB's require a single press and others require you to hold the reset button for several seconds.
