Afternoon all, problem is as follows.
Am trying to install 2 x gtx 285 's in sli. First gpu is detected and installed fine, the second is physically in the 3rd slot of a gigabyte ud3r mobo. The gpu in slot 3 is not detected by windows 7 64 bit but there are 2 small red lights towards the front of the gpu where it meets the case.
Does anyone think there is a problem with the gpu i am thinking that 2 red lights does not sound so good. Have connected the sli bridge still nothing 1st card ok 2nd same light display. I could try it in slot 2 i guess but wouldnt have thought that would make much of a difference plus if they were both "together" its a bit of a tight fit
Any and all advice greatfully received
