GPU Problems
6 Nov 2014
I just bought a new GTX 980 and have had some problems when playing battlefield 4 and other games. Before i had a GTX 660. It manged to run BF4 at about 50FPS on ultra most of the time.
I upgraded to a GTX 980 and noticed that at no matter what quality i set the game to Battlefield would still run at around 40FPS and occasionally drops as low as 10FPS.
I've re-installed the game but honestly don't know what else i can do.
At first i thought it may be a driver issue soi forced an update with Geforce experience but it didn't help.
System Specs
AMD FX8350 (4.0Ghz)
16Gb Kingston HyperX RAM
Samsung 840Evo 250Gb SSD
1Tb Hitachi HDD
GTX 980
Asrock FX990 Exterme 3 Motherboard
When i look at benchmarks for other systems online which are similar to mine they all have much higher FPS. I don't think there is a problem with my CPU as it ran faster when the GTX 660 was installed.
Does anybody have any suggestions on how i can improve my FPS in games?
Maybe check that the power cables to the GPU are properly secured, it may not be getting enough power
CPU definitely shouldn't be a problem, 8350 tears through bf4 no problem.
Have you tried reinstalling drivers after using DDU etc to remove all traces of previous ones?
Also check that resolution scale in game is set to 100%. And that you haven't selected a higher res using nvidia's DSR.
You might have the issue I have where the driver is loaded wrong on a coldboot. If you can't use Windows Aero or you can't do the Windows Experience Index, then this is the issue you have.
Don't know how to fix permanently but a temporary fix is to:
1) Computer turned off
2) Boot into Windows
3) Restart via start menu
4) Should let you do Experience Index, Aero, and fix performance.
I haven't used DDU. I didnt know that was required. I will give it a try.
Its not required, just sometimes you can get some funky problems if its left a file somewhere. I don't normally use it, but if I have problems I generally reinstall drivers after running DDU as a first resort type thing, just to make sure its not software related.
Okay, uninstalled old drives and installed new Nvidia drivers. I get about 50/60FPS on Siege Of Shanghai but still drops down to 25FPS. I am only playing at 1920x1080. I was expecting around 90FPS :L
i didn't bother benchmark this time to compare but will do soon. Atm im using Bf4 at ultra but it doesnt matter if i lower quality FPS stays about 50/60 (VSync is off).
In heaven benchmark, before uninstalling and re-installing drives i got a low of 2.5FPS, an average of 50 and a max of 168 but i never saw it at 168 :L
Metro 2033 however gets around 150FPS on max settings but it is an older game.
I have only re-installed the Nvidia drivers. I dont think i should re-install the game as i seem to have lower FPS than before in multiple games and benchmarks.
Seems like a very weird situation. What is your gpu usage in-game? If its less than 100% that would make it seem like a CPU problem, even though it was running better fps with your older card
Also, if you've got afterburner installed or anything like that, try sliding the power limit up to 120% and see if that helps?
I reckon you should do a 3d mark firestrike run. That way you can check the GPU score to see if it's in line with other 980 GPU scores (note make sure it's the GPU score, not the combined score since that will fluctuate depending on CPU, etc.). That'll let you know if the card is operating correctly and the issue is elsewhere.
What power supply do you have out of interest?
I've only ever seen my GPU run at 70% load max when benchmarking. The CPU is cooled by a H60 but the radiator is a bit loose however it never gets warmer than 50 degrees. I overclocked the CPU and it didn't help.
My PSU is a corsair 750W one. Can't remember the name of it :L
I don't think there are any power issues. I might try to swap out the PCI-E power cable but it doesn't look damaged :L
I'll try running fire strike.
