System specs, resolution and budget?![]()
plus i dont have too much to spend lolYeah, you're looking at something around the used 5870/6950 price range or maybe you can squeeze a 7850/70 if you catch a bargain.
).Not sure tbh mate. I know that I could happily run Mass Effect 2 @720p on a HD3000 (2500K) if that helps. Not tried anything more than that apart from BF3 for a laugh (was a slideshow).
think its time to get a new graphics card!
MSI HD 7770 GHz Edition 1024MB £66, a good card and a bargain at that.![]()
Second this, it also will not need much PSU power to run it and at your res + games you play 1GB VRAM is enough.
looks nice too thank you for the repliesdoes that msi gpu have the connectors for power supply as i dont have the relative 4,6,8 pin on power supply its standard psu i have
i ended up buying a an asus radeon 6700 series seems to do the job thanks everyone for replies![]()
