Turn off the central heating
Any recent driver updates ?
Yeah some drivers for my monitor
OK after some reading, it's normal for Nvidia GPUS to get hotter at higher refresh rates
Should be down clocking when idle unless you have it set to max performance in the nvidia control panel, optimal or w/e it's called is the setting you want.Ok thanks.
Looking at the picture does the GPU clock and mem clock look normal for idle ?
