My new 3090 was suffering from some bad GPU sag which was doing my head in and was painful to look at. Was looking at some brackets which screw onto the backplates but a few reviews said there was still sag with them. Saw this little stand online for around £10 and have to say it does its job perfectly.
GPU no longer looks like its about to snap the PCI-E port off the motherboard.
Just thought i would post a few pics to show how well the support stand works if anyone else was looking for a simple solution. It comes with a second post and arm for sli support. Did not need for mine so not installed.
dice 1d3
dice 1d3
dice 1d3
dice 1d3
Nice solution. Seen others use this as well in past builds with good reviews. Got a 3080 MSI trio on order and didn't realise it comes with a bracket in the box until recently but I'll see how bad it is without. Was a bit worried about this before. I have the H510 elite case and seen pictures of the same card in my case and it doesn't look like there's as much clearance as they say there should be haha.. v tight. Does fit though so there's that
