Ok firstly Hi to everyone here
and here is my current system specs:
Windows 7 64 Bit
6GB DDR2
Gigabyte GA-M720
AMD Phenom II X4 940
Nvidia XFX GTX 275 XXX
Dell 2209WA
I am looking to upgrade my GPU and have a budget of £280 max
I have been looking at a GTX570 and have found these two:
http://www.overclockers.co.uk/showproduct.php?prodid=GX-112-MS&groupid=701&catid=1914&subcat=1010
£239.99
Or an overclocked version of the above for £255
Is there any reason to get the OC version over the other, can i not just OC the standard version to the same level?
Also will my current CPU handle a 570 or would it bottleneck the 570
I am open to other cards in my budget but i thought the 570 looked a good buy and i prefer Nvidia tbh...
Thanks for any advice.
Windows 7 64 Bit
6GB DDR2
Gigabyte GA-M720
Dell 2209WA
£239.99
Time for an RMA I think
