GPU Upgrade, ok with current system?
30 Nov 2005
London
Have been contemplating a GPU upgrade for a while now. I wondered if there would be any issues with my current system if I was to opt for a NVIDIA GTX 980. I have heard some people have needed to upgrade their BIOS. Also will the CPU be the bottleneck or would I still get decent enough performance with it? Can't really afford to upgrade that just yet.
System spec below;
Corsair Obsidian 800D
Asus Maximus IV Extreme-Z Intel Z68 (Stock BIOS)
Intel Core i7 2600K 3.4 GHZ
Crucial RealSSD M4 128GB SATA (OS)
WD 300 GB Velociraptor
WD 150 GB Raptor
MSI GTX580 Lightning 1536MB
Corsair AX1200 CMPSU
8GB Corsair Dominator DDR3
Cheers
B
System spec below;
WD 150 GB Raptor
Cheers
B
Most likely you wont need to update the bios, but to be honest I would do that now anyway, as really to get the most from the 980, you should overclock your cpu and it's best to have updated the bios first before overclocking, least you update bios after overclock and then find it unstable.
Thats not to say it wont operate just fine at stock, but as I have just realised my 3570k at stock was a bottleneck in some games for my 970.
