GPU water block
9 Feb 2013
hello does anyone know what/if any water blocks there are for the vtx3d hd 7870 and if i have to go for a universal one which ones the best bet. also if i have to use a universal block whats the best vrm heatsinks to get???
Ek certainly don't make any full cover blocks for it THIS one. I don't think there is another VTX version iirc. You can always check coolingconfigurator.com for the GPU only blocks that do but I'll make it simpler for you :)
There is THIS one on OcUK but as you haven't told us exactly what GFX card you have ie specific model we can't be certain it would work. So what model specifically plz :)
Or just go down the GPU only block and any compatible one on the page should work.
Any compatible block from THIS page on OcUK
