Hello, having an issue getting my GPUs to work this morning and i could do with some help i think.
I started the PC this morning and everything seemed fine then i clicked on arma3 launcher and as soon as i did the screen went really low res on my 4k monitor. I couldnt see what caused it so i clicked shutdown then restarted the computer. The computer then booted up but would only display on my 1080p tv, the 4k monitor wasnt been recognised and the nvidia control panel had vanished. I thought something weird with the drivers was going on so i reinstalled which didnt help, then ran DDU and installed again with no difference, so i checked device manager to see both the cards had been stopped by windows due to an error. I've tried removing the SLI bridge and disabling each card individually to see if its just one of them causing be error but they both still get stopped by windows.
I've tried removing all my overclocks and reflashing my mobo bios and im just about to reflash my GPU bioses although the cards have been running underclocked for some time since i only play arma nowadays and its not very demanding so im not sure it will change anything.
Is there anything stupid im missing that you guys can think of before i start disassembling my water cooling, reinstalling the air coolers and trying the cards and pci slots out one by one as that would be a real pain.
System specs in sig.
Cheers for any suggestions.
