Graphic card ID
From what i can see on Saphire web site The RX5600XT/5700XT/5700 pulse all look the same and are the same dimensions.
Think only difference visually is the 5600XT only needs a 8 pin power where as the other two needs 8 +6 pin.
As Minibiker said, check with GPU-Z.
Can't see a RX580 that looks the same so you may have got yourself a bargain.
Did you buy it second hand? (don't mention a competitor to OCUK if you got it new)
Thanks guys I will check with GPU-Z. Mine has 8+6 pin power so could well be an Rx 5700 xt like the pc is saying. If so then that was lucky!
I got it second hand and seems to be working well
