graphic help
10 May 2009
Hello all
i found this graphic card in my house. its a sapphrie radeon hd 3650 512mb better than my current one. however when i install it. i only see parts of my screen. however if i add another monitor it adds the other part and i can use it. i however do not want this setup. is there any way this can be fixed
Do you have many gfx cards just laying about your house?
With regards to the screen display; did you remove or update gfx drivers? Is your previous card an ATI card? If your previous card was Nvidia then I recommend using drivercleaner or such like to remove any trace of drivers before you install ATI drivers.
