After speccing my friend a budget PC using just a Ryzen 2200G for graphics, he is ready to actually buy a dedicated card. He currently plays at 1080p, which I don't foresee changing any time soon.
He wants something that will last a while and give good performance now. Given he plays at 1080p, I figured either the Nvidia 1660ti or AMD Vega 56 would probably be good enough without eating into his bank account too much.
The two options I am looking at are:
https://www.overclockers.co.uk/sapp...ess-graphics-card-11276-02-40g-gx-38f-sp.html
or - https://www.overclockers.co.uk/msi-...ddr6-pci-express-graphics-card-gx-353-ms.html
Next level up is the 2060 which costs a minimum of £320 (vs £249 for the Vega 56). I am thinking the difference could be used to up his RAM from 8gb to 16gb.
If it were you, what option would you go for? The cheaper Vega 56 / 1660ti card with RAM upgrade, or spend more on the 2060?
Many thanks
Many thanks
