My 260GTX is completely blocking ALL of my SATA ports and I have 2 SATA HD's that I want to connect. I have hacked one of the cables connector to bits so that it turns flush with the mobo as soon as it comes out of the SATA socket, but I want a more permanent solution.
Are the options:
Get new mobo?
RAID controller card?
Are the options:
Get new mobo?
), it should be possible as mentioned to use either 90 degree connectors, or to bend the cable right over (not great for the cable but as long as it's not moved too much it shouldn't be a problem).
